Rip 3D Blu-ray to 3D WMV
12/25/2020
This tutorial is about how to rip 3D Blu-ray to 3D WMV video with DVDFab Blu-ray Ripper. DVDFab Blu-ray Ripper can rip any 3D Blu-ray to various 3D videos easily and professionally. It has 30-day free trial, and during the period you can try it out for free to do as many 3D Blu-ray to 3D video conversion tasks as you like. Now let’s dip into the detail.
Step 1: Start up DVDFab 9, choose Ripper option and load in the Blu-ray source
Start up DVDFab 9, and choose Ripper option. When we’re at the Ripper interface, just insert the BD into optical drive so that seconds later the source movie will be in. And the longest movie title is auto selected with audio tracks and subtitles changeable.
Step 2: Choose a profile
Open Profile box to go to 3D Format then choose wmv format. Now select a profile for the output 3D video.
Step 3: Set 3D parameters and more
Click Advanced Settings button, then in the following pop up you can see many tabs like Video, Audio, 3D, etc. And you can switch among them to set all the video and audio parameters. Let’s go to 3D tab for example, where you can choose the 3D format as anaglyph 3D, side-by-side 3D, top/bottom 3D, etc.
Click Edit button on the main interface to open Video Effect window where you can resize the source aspect ratio and frame resolution of the video, and you can crop the image for display.
Step 4: Start conversion
You can preview the title to check all settings in the right part of the main interface. Then hit Start button to start conversion if everything is OK. And you are able to view all detailed progress info clearly and easily.
OK. Done. More info about DVDFab Blu-ray Ripper, please go to: https://www.dvdfab.cn/blu-ray-ripper.htm
